RE: Throttle Problem
You mentioned earlier that you reversered the throttle. Change it back and the swash will move the right way. Then set the reversing switches also for the aileron and elevator so everything works as it should. Them plug in your motor and it should work.
After all the receiver and servo,s do not no whether they are in a blade or king.
Brian
