RE: Throttle Problem
The throttle is back to normal- not reverse. The sawash moves perfectly correct in every way I point the cyclic. The problem arises when I throw throttle in there. The swash should go up to increase the pitch of the blades. Instead, it goes down.
I have the eflite Rx on there- when I plug in the Esky one, it does the same exact thing.
