ORIGINAL: flyinsolo11
The throttle is back to normal- not reverse. The sawash moves perfectly correct in every way I point the cyclic. The problem arises when I throw throttle in there. The swash should go up to increase the pitch of the blades. Instead, it goes down.
I have the eflite Rx on there- when I plug in the Esky one, it does the same exact thing.
My buddy just went through this with his king. He also used the blade trans & receiver. He had to use the eflite blade s 75 servos to get it working.this is important Esky-hitec servos will not work.
If you put the throttle in reverse then the pitch will go the right way. After you do this hook up the motor and see if it is working properly.
Example do you have the motor hooked up and is it arming properly( its a good idea to remove blades while fooling around here) and spinning up.
Brian
Brian
