ct420 you are absolutely correct but, you can change the rotation of the esky servos to match the rotation of the eflite servos and that will take care of his problem if he doesn't want to by another transmitter. Of course the wise thing to do is by a progammable transmitter but that might no be an option for him right now. So I am saying if it works with the with the esky servos and transmitter then it will work with eflite transmitter and the esky servos with the mod or simply change the servos. It will work. The only difference it the rotation direction of the servos in stock mode. If he changes the esky servos to rotate the other direction he will have to switch the elevator, aileron and throttle swiches when he is done because when you change the servo then the elevator, aileron and throttle will be backwards and you can switch them with the transmitter from the stock position. The transmitter does not have a reverse switch but, it can be done manually with the polarity of the servo motor.
Gittle
