RCU Forums - View Single Post - Could i pull it off?
Old 01-19-2008 | 10:17 PM
badazzbusa
Default RE: Could i pull it off?
If you can follow directions then they are easy to build. I recommend building so when she goes down it won't be so intimidating to repair. You might need some help with the set up of the electronics and programming but you can find someone local or someone here can help you out.
