RCU Forums - View Single Post - JC flameout question
Old 01-20-2008 | 01:16 AM
KC36330
Default RE: JC flameout question
when i had a bad batt it had 'Power Fail' , only other flame out i had said the same thing and it was caused by the smoke pump on a Y with the ECU batt and the pump broke a gear and locked up causing a high current drain on the ECU batt drooping voltage below ECU cut out.
