RE: First Crash....need help
it may be normal for the rotor head to turn from cyclic inputs because of the one-way gear...
however, regarding your high pitched whine i would bet that your motor moved in the crash and the pinion is now hard against the main gear, OR you have stripped the main gear and it needs replacing
