RE: P82 Twin mustang electric conversion
I saved a lot of wiring by using two receivers.
If I remember correctly, when I converted to two receivers on this plane, I went from connecting 16 wires to either two or four when at the field.
For balance, I had to add a battery in one fuse anyway to compensate for the battery in the other fuse, so it was not much weight to also add the second receiver.
