RE: Rx Switch?
I'll often use a standard switch (the weight difference for sport use is negligible). I've also used an aileron extension as a switch...with a male plug that's had the leads soldered together. Lightweight and positively fail-safe (unless you accidentally snag the plug out on hand launch). I used one of them very effectively on an Ultra Sport 40, I had it mounted behind a flip-up hatch.
