RCU Forums - View Single Post - H9 Arrow RTF throttle servo problem? Or not?
Old 01-20-2008 | 08:41 PM
Scott_S.
Default H9 Arrow RTF throttle servo problem? Or not?
Hello, while going over my new Arrow RTF, I've noticed the throttle servo twisting about as much as it can in it's rubber mounts.
I'm pretty sure this is due to the horn position but not sure. At idle or off, the servo linkage seems to be well past a comfortable center.
As you throttle up the linkage has to "pop" past this position. It all works fairly smoothly with the exception of the servo will move
in it's rubber mounts about 1/16 of an inch. IT IS THE SERVO ON THE LEFT.
The LEFT PHOTO is at idle/0ff position......MIDDLE PHOTO is at half throttle........RIGHT PHOTO is full throttle
Notice the line of movement is nice and straight from half to full throttle.
But......look at the line of movement from idle to half (or full)
Thanks and I appreciate any thoughts. I may be worrying about nothing but I'd like to have it as close to perfect as possible.
ID:	856436   Click image for larger version
ID:	856437   Click image for larger version
