RE: Yak 86" Ballance
Im 16.1lbs with DA-50 on MTW Canister. I have 3 Fromeco 2600's (1 for ignition) (2 for rx & servos), with 2 Fromeco Regulators, Wolverine Dual switch for RX and a Fromeco Badger switch for ignition. Im using 5985's on Elevators & Ailerons, 5955 on Rudder, with standards on throttle and choke.
Im using an XPS 2.4ghz (soon to be FASST), 20oz Dubro Tank, Carbon Undercarrage, Carbon PT Model Prop, Carbon spinner, with light weight Karvan wheels and no wheel pants (as they are not verry scale like)
I could get it under 16lbs by taking the Ignition Regulator and Lithium off and replacing it with a 1800nimh and also putting standard pitts or side dump muffler system. I would be guessing but it would be around 15.5lbs without canister and a lighter system on the ignition.
