RE: roll cage
yeah and the rear mount is kind of a "hinge"
i have my rear mounted solid,, and the front i drilled the mounts out a little and have a tight pin and it's setup so that it's qwick release, you just unhook the lock, pull the pin, and you can flip the whole cage up out of the way to work on the truck.
