RCU Forums - View Single Post - Hangar 9 Arrow RTF idle trim question.....
Old 01-20-2008 | 09:42 PM
Scott_S.
Default RE: Hangar 9 Arrow RTF idle trim question.....
Thanks HighPlains,
I have servo hum at any trim setting less than half but at half there is zero opening on the barrel.
I just checked it out again, it appears that servo was never meant to be at low throttle with trim bottomed out,
that's what was binding it. At full up trim I have almost the 1/16 inch opening but at full throttle its not full open.
After I adjust the carb linkage out it should be fine. I may rotate that horn too.
Thanks!
