RE: Engines stops
I will try that. The engine was producing exactly 10000 rpm with the OS#8 plug and happily idling at 2300rpm. (of course that is assuming the electronic rev counter is correct, although I guess all the readings will able to be compared if the same the same rev counter is used.)
David
