RCU Forums - View Single Post - FS One by Hangar 9
Old 01-20-2008 | 10:07 PM
  #1483
LearJet1
Default RE: FS One by Hangar 9
ORIGINAL: sctholson
ORIGINAL: sctholson
Lear,
I just checked the throttle hold on a stock Trex450 and it works fine. This is all about channel and axis assignments. I guess my suggestion for you at this point is to work backwards, eliminate all the axis' that already work fine, and experiment with those that don't work. Example: look at the top most line in the transmitter edit, what axis does yours show? Mine is axis 6 and it controls on of the basic 5 control surfaces, that means the Throttle hold on your TC9CAP isn't on Axis 6. I'd just keep going through each channel and after you exclude the 5 basic controls, work with what's left. I don't know how else I can help with this, since I don't have a TC9CAP.
Good luck
Scott H
Lear, have you tried to set your radio like the FAQ:
http://www.inertiasoft.com/fsonefaq/...html#Q1028-FS1
I imagine that one of these of switches is your throttle hold, spend a few minutes here to get some experience and you should be able to set any axis you need.
Scott H
Yes I have setup several planes and helis using this FAQ. I haven't had time to go thru and eliminate all axis assignments for the TRex. I don't think that FSOne supports anything except the DX Transmiters with Throttle Hold and the TRex. Is the DX a seperate entry in the transmitter selection? Are you using the wireless interface for the DX? That might explain why I don't see it on my transmitter selections list. I will pursue this further when I get time. Right now tomorrow is indoor fly time and the WX is getting into the 60's for more outdoor time. Thanks for the interest!
