RE: Steering Servo? Or Steering Problems?
You bent the dogbone by hand [X(]
My guess is that since it is bent, it is now not spinning true and is binding in the diff outdrive or the steering knuckle drive cup.
Pics would help alot.
You could try turning the front wheels by hand with the steering turned either way and see if it binds.
I have no clue if it is even possible but if you hit it hard enough you could have jolted the servo hard enough to throw it off it's center (if anyone knows what I am trying to say[sm=bananahead.gif]) Did it turn wider in one direction more so than the other?
