RE: Nitro 90" (1/7 scale)P-38J Build with mods
Never done this before (on an ARF), but so far, it seems to be going well. I now have the Port side outer panel tube and sleeves in place and glued up. I used Gorilla glue on the inboard section as well, since it worked so well on the other panels and it gives you plenty of time to get everybody lined up. An aluminum wing tube is stretch wrapped (this stays tight where as tape stretches and gets loose) in place to keep the panels straight. Tonight, the other side, then I can start to work on the end plates.
