RCU Forums - View Single Post - Control throws for Ultimate 40 Bipe
Old 01-21-2008 | 01:54 PM
opjose's Avatar
opjose
Default RE: Control throws for Ultimate 40 Bipe
IMHO: It's hard to get TOO MUCH throw out of the ailerons on this plane.
Maximize the throws and then set your TX to use about 60% of this for the low rates with about 20-25% expo and full travel for the high rates at 50% expo.
For the elevator use the recommended setting for the low rates at about 35% expo, and about 1/2" or so MORE for the high rates with 50% expo.
For the rudder again use the recommended setting for low rates, but at 15% expo and ALMOST as much as you can get for high rates at 50% expo.
Fly the plane with low rates and once you have it trimmed out ( BE PREPARED! ), and HIGH in the air, try out the high rates to determine if you want less.
