RCU Forums - View Single Post - Hyde engine mount in a profile model?
Old 01-21-2008 | 02:31 PM
AFSalmon's Avatar
AFSalmon
Default RE: Hyde engine mount in a profile model?
You're welcome Glover. Not sure if the Saito is any worse or not than the YS. I'd say the two brands are probably the same as far as vibration given the same size motor. The 110 being only slightly bigger than the 100 might have a little more moving mass which equates to more vibration.....maybe. There are a lot of factors. The YS would spin a bigger prop as well than the Saito 100. Bigger prop means more rotating mass and thus more torque transferred to the airframe. If you had a choice on engines I'd go with the Saito 100 for the Ultimate. Way more than enough power and sounds good on the bipe as well!
