RCU Forums - View Single Post - Hyde engine mount in a profile model?
Old 01-21-2008 | 04:55 PM
MRMcFarlandM's Avatar
MRMcFarlandM
Default RE: Hyde engine mount in a profile model?
As many of the others have said 200 hundred flights does not seem like a lot of flights to me. I don't understand why the engine should ever shake the plane apart if everything is kept balanced. On the soft mount. The profiles I have soft mounted I used lords mounts and acouple of aluminum plates. It really will cut vibration, but the problem of the plane tearing itself apart at idle I am not sure you can do much for it.
