RCU Forums - View Single Post - How much torque is on the GEAR.
Old 01-21-2008 | 07:47 PM
twomanytoys
Default RE: How much torque is on the GEAR.
You really cant measure torque from the engine. There are wayyy too many variables. Flywheel size, clutch spring tension, clutch shoe size, ****ch shoe material, tuning, carb size, pipe and header combination, temperatures, clutch bell teeth size, gearing, tire size, truck weight etc... You can get manufacture ratings but this is on dyno with no load and most all are not accurate.
