RE: Multiplex Easy Star, construction, flight report
Hi everyone. I'm just about finished building the Easystar. Should the wing be fairly easy to take apart? I made sure that the spar connector was not glued to the wing. I know that because prior to inserting the wing into the fuselage, I was able to connect the wing and disconnect. I did this a couple of time before connecting it to the fuselage. Now the wing is connected to the fuselage and I'm having a heck of a time separating it. Is there a secret or tip to detach the wings from the fuselage? I've been pulling quite hard but at the same time feel that any harder I might break something. Do I start separating the wings from the leading edge? Any advice is greatly appreciated. Thank you.
