The Dapters will work fine with the stock LiPoly version of the AF 109. I charged my first 3S and 4S A123 with such for a while before I modified it and I also convinced Charllie Wang (Mr. Thunder Power) to add A123 support to the TP-1010C charger. I have done Beta testing for TP.
No the dapters will not work in discharge mode but then they are not needed then The AF 109 (LiPoly ver.) will not discharge A123 low enough to get a good capacity test and in fact the discharge rate is so low that you really do not want to discharge them to a low voltage anyway.
My A123 charging Thread on RC Groups including AF 109 and Dapter
http://www.rcgroups.com/forums/showthread.php?t=603368
Charles
