RE: Engines stops
Problems solved. Thank you all for your help. I adjusted the low speed needle valve slightly, richening the engine by about 1/10 of a turn. Problems gone. Now idling @ about 2300rpm and toping out @ 12500 rpm. No hesitation in moving from idle to full power, mid throttle to full power, full or mid power down to idle with the engines continuing to idle and not dieing(stopping). Engine just purrs, doing all the things a glow engine should.
Just need the rain to clear away and flying again. (tomorrow???)
Cheers
David
[8D][8D][8D][8D][8D][8D][8D][8D][8D][8D][8D][8D][8D][8D]
