RCU Forums - View Single Post - P40-E 60 size ARF problems.
Old 01-22-2008 | 09:07 PM
BryanSinHou
Default P40-E 60 size ARF problems.
I just ordered and recieved a P40-E Warhawk 60 sized ARF. I am starting to build it and have encountered a few problems. After reading through the instruction maunal, It looks like there are a few steps in the instructions missing. Particularly page 2 where it talks abou tthe airleron servo hatches. I cut away the material from the bottom of the wing after matching the approximate placement of the servo hatch, not listed in the instructions. Also, the hatch is about 1/8" larger than the size of the opening for it between the ribs. Is there a problem with this kit or maybe the accessories packages were mis-matched to this 60 sized for a 90 or something like that? Also on page 7, there is nothing but a blank space where I guess the arrows to where the elevator and rudder and throttle servos should go in the fuse. I found a piece of ply that has a slot where a servo would go (I assume for hte throttle) in one of the accessory packages and it barely fits in the fuse. I was told by a friend to contact this forum on these questions, but should I instead contact the company directly about possibly sending this kit back for a replacement?
Thanks for any help you can provide either via this forum or to my direct email: [email protected]
Bryan Saldana
