RCU Forums - View Single Post - Redcat Monsoon Thread
Old 01-22-2008 | 09:22 PM
  #276
vnmsgt's Avatar
vnmsgt
Default RE: Redcats Monsoon Thread
Check out this mod I found for the Monsoon and hurricane so you do not have any problems with the screw on the servo rod hit the upper plate when steering. All you have to do is loosen you servo saver and rotate the upper part of it 180 degrees and tighten it back down and then readjust your servo arm.
