RE: Hyde engine mount in a profile model?
What about putting the bolts in front and behind the flange then you don't have to drill out the motor flanges. You could make it so you still use fule tubing and maybe some carbon fiber guide pins to locate the engine and then still use the aluminum plate and silicone over and under the motor flange but with the bolts in front and behind the engine. How does that sound?
