RCU Forums - View Single Post - New SV Gassers
Old 01-23-2008 | 01:39 AM
  #343
freeonthree's Avatar
freeonthree
Default RE: New SV Gassers
Just go step by step, and check em off as you go. On the SV26 mounting stabndoff's, make sure you put fender washers behind the firewall, and loctite the bolts in there. The bolts by themselves will sink into the wood if ya don't, and the engine will then be loose. I found out the hard way, and had to pull the darn tank to redo it. I think the standoffs are large enough diameter to not sink unless their allowed to come loose and then the vibration will pound them into the wood. And of course, avoid any metal to metal moving parts or linkages that can cause radio interference.
