ORIGINAL: JochenK
using a swashplate solution is more or less a must for the Rotodyne...Think of how high your rotormast will have to be to get you enough clearance at the back of the Rotodyne. It won't look good anymore.
I'm of the opinion that, unless it's strictly necessary, it's better to avoid swashplates. I don't know which particular setup used the Rotodyne, but it seems like there's plenty of space for the rotor to tilt. But, to know for sure, it's as easy as finding a good side view of it, drawing a "fuselage mean line" and a rotor path line tilted 9º-12º degrees from that "mean line". If you can then draw another rotor path tilted an extra 10-12º degrees (I'd say not more than 25º overall) and still have a good clearance, then there should be no problems. And those angles should be more than enough. The Rotodyne has a small wing which should provide some lift, thus allowing the rotor tilt angle to be reduced.
Regarding that, the rotor-wing dependance can lend to interesting experimentation. Brainstorming a bit,
- A high-lift wing (= wing provides most lift) would allow you to have a less-tilted back rotor in normal flight -> Less drag -> Somewhat higher velocities and "plane-like" behaviour. You could still allow the rotor to tilt back many degrees, to help with low-speed handling. Anyway, you should always keep the rotor at a minimum angle; else, if you're flying in certain conditions, you could even stop the rotor.
- A low-lift (or nearly 0 lift) wing means the Rotodyne would get most of it's lift from the rotor -> More drag -> Behaviour closer to a "pure" autogiro.
In any case, though, remember to keep the weight really low...Or it will fly like a plane anyway!
ORIGINAL: fogarty
I recently found a RC DVD I made 5 years ago at LDMFA field in Australia and have been uploading clips to Youtube for posterity , Saw your Rotodyne discussion & thought this clip could be of intrest [link=http://www.youtube.com/watch?v=17i43MTx4o8]RC Rotodyne[/link]
It's hard to say this but, that model flies like a drunk hornet. I'm still amazed by how it could survive 2 flights.
