RE: Running in sub-zero temps?
I think most would not recommend breaking them in with it so cold..
Engine can be running at 220 and be running to lean,
I think if you wrapped the head in something to keep the temp up without having to over lean it.
But I've never broke and engine in with it that cold, coldest i've run is 35 degrees..
I should of wrapped the head cause i couldn't get it to temp without overly leaning it,
