RCU Forums - View Single Post - BME 50 owners advice needed
Old 01-24-2008 | 12:21 PM
tankertoad's Avatar
tankertoad
Default RE: BME 50 owners advice needed
Here's a couple more pics. It looks like there is only one screw that holds the metal tab that the sensor is mounted on. It appears that any movement of the tab would take the sensor out of the path of magnet. There is also a small black allen screw in the prop hub. Is that for changing the hub's rotational position on the crank shaft, and changing timing?
ID:	859665   Click image for larger version
