RE: lst 2 brake adjustment
Set your EPA (End Point Adjustment) on your Radio.....
Press the Scroll key till you see EPA, Then Press Channel key once you should see “TH” (Throttle Adjustment) Push the Trigger for Brake
Adjustment, Then Press the Increase or Decrease keys to select the Desired Servo Travel......
