RE: Yak 86" Ballance
Very clean set up there. I have to warn you though. The choke and throttle servo plate will want to come loose without washers under the bolt heads. Mine came loose and were installed with blue Locktite in a vertical manner. I dont know how they vibrated up ward. I also have my tray slid all the way back on the fuse and there are 4 bolts going threw the plate on that back section and into the fuse. Still came loose in flight once.
