RCU Forums - View Single Post - AXE CP Drifts Left
Old 01-24-2008 | 10:14 PM
a2j812
Default RE: AXE CP Drifts Left
I'm having the same issue with the heli constantly sliding to the left, however if I give it right cyclic it tends to tip to the right instead of sliding back to the right. Is that normal as well? Also, how to they expect you to learn to "HOVER" on the ground if you can't correct the left slide? Also is it normal for the heli to swing under the blades when it is actually in the air?
Thanks for the help. Sorry if this is a repeat post, but I wasn't able to find anything about the swing thing.
