RCU Forums - View Single Post - Ignition Battery Switch
Old 01-25-2008 | 08:56 AM
rrritchey
Default RE: Ignition Battery Switch
Hi Doug,
I do not use a switch on my ignitions any more. I just use the Cutoff receiver module as the switch. The module will draw a few milliamps a day from the battery in the off position. I disconnect mine when I am home to charge anyway. I don't think you would have a problem unless you left it for a long time without disconnecting or charging.
