RE: Ignition Battery Switch
The problem is that this is a warbird and the ignition battery will be in the Engine Compartement closed in by the Cowl; to disconnect the Battery would be a pain because you would have to remove the Cowl to do so, and I would like to avoid placing a switch on the surface, however; your Pin/Flag switch is so unobtrusive; leaves a small footprint on the surface, no more than an earphone jack, is there a way to modify it to work like a ON/OFF switch by inserting the pin.
Doug.
