RCU Forums - View Single Post - CG Super Chipmunk thrust angles
Old 04-16-2003 | 06:46 AM
nashtm
Default CG Super Chipmunk thrust angles
Thanks for the replies,
I should have been more specific - it ballooned when I chopped the throttle on landing so I removed some of the down thrust which sorted that out.
But in full power verticals it pulls left some much that I need almost full right rudder. It also only has enough rudder to hold it in a knife edge with left rudder.
I have put in a washer for right thrust and will test it.
Is using a mix on the radio an good solution ?
Tim
