RCU Forums - View Single Post - AXE CP Drifts Left
Old 01-26-2008 | 02:53 AM
mensaboy
Default RE: AXE CP Drifts Left
the "flip flop" from positive pitch to negative pitch due to slop in the rotor head is what causes this
if you have a high enough head speed to maintain a hover with very little pitch, as soon as you go near zero pitch, the linkages allow one of the blades to 'flop" over to negative and get that sudden, powered decent
the only way to alleviate this in a bird with the AXE's slop, is to increase the pitch at lower throttle, so you will descend well before zero pitch due to lack of head speed
or get rid of the slop with a metal center hub/flybar system, ala microheli
the other, less likely possibility, is that you have your flybar paddles on reversed
