RE: Nwe to gas--help!
Huh? I thought the question was if he had to use a specially made gas engine kill switch or if he could use a regular switch disconnecting the ignition battery. I'd like to know too as I am also new to gas engines.
I would think a normal switch mounted away from the receiver so that it would not cause interference would work fine. I would question if there would be enough separation mounting the kill switch in the cockpit.
John
