RCU Forums - View Single Post - how to do a pyro flip?
Old 01-26-2008 | 08:06 AM
paulaballa
Default RE: how to do a pyro flip?
ORIGINAL: kenhiraihnl
ORIGINAL: paulaballa
I keep trying to learn but I dont know exactly what do,I I try to spin while trying to get it to flip but most of the time it wont flip
i don't even fly inverted yet (not intentionally, anyway)...just mild aerobatics...however, i copied the following from a post about what to learn after nailing mild aerobatics...here it is...let me know if it works...ken
"Pyro Flip
Really easy if you think about it. Start from inverted tail to you. Pull back and when the bird is straight up and down give it a 180 with the tail, then push forward to finish the move. You dont have to give the stick a swirl when your trying it for the first times, just start with back elevator and then goto forward elevator.
The collective timming is the same as a normal flip. You just have to have your 180 down to stop it where you want it. A little easyer to be a touch slow with the rudder at first to make sure you can stop it where you want.
Then when you get the hang of it, start to swirl the cyclic to smooth it out and lose less alltitude. Left rudder, clockwise swirl."
nope that dosnt work it needs to be spinning the whole time, this is what im looking to do http://www.youtube.com/watch?v=2sqLt-3o_FI&NR=1
