RCU Forums - View Single Post - Flexing Horizontal Stab?
Old 04-15-2003 | 07:32 PM
Montague
Default Flexing Horizontal Stab?
oh, btw, when looking at the flex, if the bend is spread along the surface, then it's not broken. If all the flex appears at one point, espeically the joint with the fuse, then it's broken or loose. I don't know if that's clear, but it should be obvious when you look at it carefully.
