RCU Forums - View Single Post - Tamiya Nitrage 5.2, The Offical Thread
Old 01-27-2008 | 07:08 AM
  #107
joelgould111
Default RE: Tamiya Nitrage 5.2, The Offical Thread
ok here is the best set up
This is a general outline for setting the tamiya nitrage up for racing.
center diff fluid: 11000
rear diff fluid: stock
front diff fluid: stock
rear shock fluid: 70
front shock fluid: 60
rear sway bar: hard
front sway bar: none
front brake: 60%
rear brake: 40%
toe out: 2 degrees
also, to help the handling and acceleration,
remove the stock tires, and add 1/8 truggy race tires, the rims provided actually fit those standard size tires....and handling is greatly improved
that is a verry good setup im using it at the moment
