RE: Throttle Problem
I have a new e-sky 4-in-1 controller (EK2-0702A) on my HB CP2 with standard e-sky transmitter (0406A). When I throttle up, it pushes the swashplate up, reducing pitch on the blades (in fact, the blades pitch goes negative with 50% throttle and above). All swashplate controls are correct except for throttle. This is the opposite problem from that of flyinsolo11; so, I am interested in any reasonable solution. Is there a way to program throttle curves in a 4-in-1, or in our case, reverse the throttle curve? Maybe, flyinsolo11 and I should just swap controllers.
