RE: Skymaster F-4E phantom
Here is the response I recieved from Mr. Li Kai which demonstrates the solution for this issue if any one you having this problem. I thought its an elegant solution and I should post it for all the SM F4 pilots to see. Thanks againg for speedy support from Skymaster crew, and Mr. Li kai.
I will make the modification and will update you guys as to the performance improvement.
Jason
