RCU Forums - View Single Post - YS 63FZ Mid Range Running Problem
Old 04-15-2003 | 11:07 PM
Dave Black
Default Ys 63
Thanks Deputy,
The temp here in Pretoria is in the early 70s at the moment. the engine was not worked hard and did not seem to run hot at all. I could still touch the valve cover after the 3Min run. What I find weird is that it runs fine at full throtle and at idle but likes nothing in between. I checked nipples -Facing the engine The right line goes to the tank via the check valve for press and the left one from the tank to the engine via fuel filter. I have also just released the press now which has held for two hours.
