RCU Forums - View Single Post - Pieces needed to complete a conversion
Old 01-27-2008 | 03:38 PM
DaveFlynn
Default RE: Pieces needed to complete a conversion
You could try a 9S1P 2100mAh 16-20C and a 12x4, 12x6 prop. Check the amps, should max out at about 30 on the ground. Expect performance like a good .46, about 850 Watts. Or, 9S1P 3200mAh 20C and push to 45 Amps max, 1200 Watts with a 13x6 or 14x4 Prop. What I like to do is, first time out take a good selection of props, start with a 12x4 and test, go more pitch or bigger until I get to 90% of the rated amps of the ESC or battery which ever is less.
