RCU Forums - View Single Post - trouble startin .52
Old 01-27-2008 | 03:58 PM
opjose's Avatar
opjose
Default RE: trouble startin .52
It sounds like it's hydro locking.
NEVER turn a broken in engine by hand if you feel a lot of resistance. You can break the piston rod doing this!
ABC engines will have a LOT of resistance initially when they are new.
The Evolution comes "pre-run" from the factory so it will not have an undue amount of resistance to be turned over.
BTW: Do you mean EVO, or Evolution, these are two different manufacturers?
Remove the glow plug and turn the engine over by hand.
Do you feel about 30%-40% more resistance with the glow plug installed, than with it out?
If the engine feels very easy to turn over w/o the glow plug, but very hard in your prior experience, then it's hydro lock.
