RE: Black Magic VF3 Build Thread
<<The only problem which is not much is when the servo needs installed or removed are the servo screws. I will have to use the button head type along with an allen wrench. I will use this type setup on all my planes.>>
A solution to this is to make the servo mount itself removable. The screws for the mount could then be oriented vertically for easy servo removal.
