RCU Forums - View Single Post - brushless esc
Old 01-27-2008 | 05:19 PM
acarter's Avatar
acarter
Default RE: brushless esc
This may not be your situation, but if your talking about the beep when you put your battery in then this may be your problem: When you plug your battery in (or turn on the switch) you have to move your throttle stick all the way up and then all the way down and then the prop should spin when you go back up. This does not apply to all esc's and may not be your problem, just a suggestion.
Austin
