RE: Need some help!
You typically want about a pin's width or just a bit more of space showing.
But as he said it's not going to be a big problem on a trainer.
Most trainers have relatively small control surfaces and overspeeding the trainer is never a problem.
If anything having some gap makes the CA joints a bit more flexible and less likely to bind or hold up the servos.
